Giriş
We will be replacing the small camera module in the tablet. This may be necessary due to lint/dust buildup in or around the camera lens.
Neye ihtiyacın var
Wedge the opening tool in the space between the back and the front of the tablet.
Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
When the back of the tablet is mostly detached from the front, carefully pull it away completely.
Peel the black tape back and pull the black tab back (the tab should come up, not slide).
The camera module should then easily come out. Insert your replacement module.
Bir başkası bu kılavuzu tamamladı.
