Ana içeriğe geç
Digital2 D2-912 Motherboard Replacement
Neye ihtiyacın var
  1. Digital2 D2-912 Motherboard Replacement, External Cover: adım 1, 1 resimden 1.
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Motherboard Replacement: adım 2, 2 resimden 1. Digital2 D2-912 Motherboard Replacement: adım 2, 2 resimden 2.
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • Remove the wires shown in the image, using a soldering iron and solder sucker.
    • By removing the wires, you are detaching the battery and speaker from the motherboard.
  4. Digital2 D2-912 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the three screws from motherboard.
  5. Digital2 D2-912 Motherboard Replacement: adım 5, 2 resimden 1. Digital2 D2-912 Motherboard Replacement: adım 5, 2 resimden 2.
    • Detach the capacitive touch controller from the motherboard.
    • Carefully pry the narrow black connector upward to release the ribbon.
    • Remove the ribbon from the connector.
  6. Digital2 D2-912 Motherboard Replacement: adım 6, 1 resimden 1.
    • Locate the camera found in the image.
    • Carefully pry the black connector upward to release ribbon.
    • Remove the black tape to release the camera from the motherboard.
    • Remove and replace the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jason Wignot
322 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Fall 2015 IUPUI, Team 1-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 380
