Giriş
We are going to teach you how to remove the tape that's holding the battery down and where to remove the soldering that is holding the battery to the motherboard. This guide can be used if you have had power/charging trouble with your device. Make sure to know how to solder in order to anchor wires to motherboard using this guide if you need help Soldering Skills .
Neye ihtiyacın var
Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
Desolder the wires that are connecting the battery to the motherboard. For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
Then pull away the battery.
