Ana içeriğe geç
Digital2 Platinum Pad 9 Battery Replacement
Neye ihtiyacın var
  1. Digital2 Platinum Pad 9 Battery Replacement, External Cover: adım 1, 1 resimden 1.
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Battery Replacement: adım 2, 2 resimden 1. Digital2 Platinum Pad 9 Battery Replacement: adım 2, 2 resimden 2.
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Battery Replacement: adım 3, 2 resimden 1. Digital2 Platinum Pad 9 Battery Replacement: adım 3, 2 resimden 2.
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  5. Digital2 Platinum Pad 9 Battery Replacement: adım 5, 1 resimden 1.
    • Carefully remove the tape that is holding down the battery.
  6. Digital2 Platinum Pad 9 Battery Replacement: adım 6, 2 resimden 1. Digital2 Platinum Pad 9 Battery Replacement: adım 6, 2 resimden 2.
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  7. Digital2 Platinum Pad 9 Battery Replacement: adım 7, 1 resimden 1.
Sonuç
David DeMeritt
637 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G6
3 Üyeler
Bir Yorum
Where can one buy the battery?
BedfordGlen Board - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 293
