Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
We are going to teach you how to remove the external cover on the Digital2 Platinum Pad 9 tablet. Getting the cover off is a little tricky and takes a bit of force.
Parçalar
Hiçbir parça belirtilmedi.
  1. Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. After inserting the plastic opening tool, run it around the device a few times to loosen the external cover. After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  4. Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up. Then just remove the backing.
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
Sonuç
David DeMeritt
613 İtibar
6 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 199
