Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
We are going to be replacing the external speakers of the Digital2 Platinum Pad 9.
If you have tried to troubleshoot the device and still had no luck then you would resort to using this guide in order to replace the speakers with new units. So before you begin the external speaker replacement you should first feel comfortable taking apart your device. You should also be able to solder the wires to the motherboard, use this guide by ifixit to learn how to do this step Soldering Skills.
Neye ihtiyacın var
Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
The external speakers are located in the black plastic fixture near the battery as pointed to in the image.
Desolder the wires. For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
Then just pull them off the tablet.
