Ana içeriğe geç
Digital2 Platinum Pad 9 Motherboard Replacement
Neye ihtiyacın var
  1. Digital2 Platinum Pad 9 Motherboard Replacement, External Cover: adım 1, 1 resimden 1.
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Motherboard Replacement: adım 2, 2 resimden 1. Digital2 Platinum Pad 9 Motherboard Replacement: adım 2, 2 resimden 2.
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Motherboard Replacement: adım 3, 2 resimden 1. Digital2 Platinum Pad 9 Motherboard Replacement: adım 3, 2 resimden 2.
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Motherboard Replacement, External Speaker: adım 4, 1 resimden 1.
    • The external speakers are located in the black plastic fixture near the battery as pointed to in the image.
  5. Digital2 Platinum Pad 9 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a J0 sized Phillips head screwdriver to remove the two 3.175mm long Phillips head screws from the speaker fixture.
  6. Digital2 Platinum Pad 9 Motherboard Replacement: adım 6, 1 resimden 1.
    • Then lift up the cover holding the speakers down.
    • Remove the actual speakers along with the cover.
  7. Digital2 Platinum Pad 9 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the tape holding the wires down.
  8. Digital2 Platinum Pad 9 Motherboard Replacement: adım 8, 1 resimden 1.
    • The two wires that connect the speakers to the motherboard must be removed next. In order to replace the speakers you will need to solder them back into place.
  9. Digital2 Platinum Pad 9 Motherboard Replacement: adım 9, 1 resimden 1.
  10. Digital2 Platinum Pad 9 Motherboard Replacement, Battery: adım 10, 1 resimden 1.
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  11. Digital2 Platinum Pad 9 Motherboard Replacement: adım 11, 1 resimden 1.
    • Carefully remove the tape that is holding down the battery.
  12. Digital2 Platinum Pad 9 Motherboard Replacement: adım 12, 2 resimden 1. Digital2 Platinum Pad 9 Motherboard Replacement: adım 12, 2 resimden 2.
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  13. Digital2 Platinum Pad 9 Motherboard Replacement: adım 13, 1 resimden 1.
  14. Digital2 Platinum Pad 9 Motherboard Replacement, Volume Buttons: adım 14, 1 resimden 1.
    • You can locate the volume buttons on one of the longer sides of the tablet.
  15. Digital2 Platinum Pad 9 Motherboard Replacement: adım 15, 1 resimden 1.
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  16. Digital2 Platinum Pad 9 Motherboard Replacement: adım 16, 1 resimden 1.
    • Then remove the ribbon cable from the ZIF connector.
  17. Digital2 Platinum Pad 9 Motherboard Replacement: adım 17, 1 resimden 1.
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  18. Digital2 Platinum Pad 9 Motherboard Replacement: adım 18, 2 resimden 1. Digital2 Platinum Pad 9 Motherboard Replacement: adım 18, 2 resimden 2.
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
  19. Digital2 Platinum Pad 9 Motherboard Replacement, Front/Rear Facing Camera: adım 19, 1 resimden 1.
    • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
  20. Digital2 Platinum Pad 9 Motherboard Replacement: adım 20, 2 resimden 1. Digital2 Platinum Pad 9 Motherboard Replacement: adım 20, 2 resimden 2.
    • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
    • Then use your hand to lift up the cameras.
    • Make sure not to tear the ribbon cables.
  21. Digital2 Platinum Pad 9 Motherboard Replacement: adım 21, 1 resimden 1.
    • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
  22. Digital2 Platinum Pad 9 Motherboard Replacement: adım 22, 1 resimden 1.
    • Finally remove the cameras.
  23. Digital2 Platinum Pad 9 Motherboard Replacement, Motherboard: adım 23, 2 resimden 1. Digital2 Platinum Pad 9 Motherboard Replacement, Motherboard: adım 23, 2 resimden 2.
    • Use a J0 sized Phillips head screwdriver to remove the three 3.175mm long Phillips head screws from the motherboard.
  24. Digital2 Platinum Pad 9 Motherboard Replacement: adım 24, 2 resimden 1. Digital2 Platinum Pad 9 Motherboard Replacement: adım 24, 2 resimden 2.
    • Insert the plastic opening tool to pop up the ZIF connector holding the ribbon cable down.
    • Remove the ribbon cable.
  25. Digital2 Platinum Pad 9 Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove the ribbon cable from the ZIF connector, it is next to the volume buttons.
  26. Digital2 Platinum Pad 9 Motherboard Replacement: adım 26, 1 resimden 1.
    • Desolder the connections that are soldered to the motherboard. For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
    • Then remove the motherboard by lifting it away.
Sonuç
David DeMeritt
637 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 223
