Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will teach you how to remove your front/rear facing camera so that you can replace them. This is for if your cameras are not functioning properly or not working at all. You should feel comfortable taking apart your device and using a plastic opening tool to do so. You will also need to be able to identify components of your device and you can learn to do that by following this guide here Recognizing & Disconnecting Cable Connectors.
Parçalar
Hiçbir parça belirtilmedi.
  1. Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. After inserting the plastic opening tool, run it around the device a few times to loosen the external cover. After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up. Then just remove the backing.
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. The front/rear facing cameras are located in the corner of the device one is facing toward you and is black.  The other is facing away so you will see the white backing.
    • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
  6. Use the plastic opening tool to pop up the cameras from their slot in the Tablet. Then use your hand to lift up the cameras.
    • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
    • Then use your hand to lift up the cameras.
    • Make sure not to tear the ribbon cables.
  7. Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
    • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
  8. Finally remove the cameras.
    • Finally remove the cameras.
Sonuç
David DeMeritt
613 İtibar
6 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 56
