Ana içeriğe geç
Digital2 Platinum Pad 9 Volume Buttons Replacement
Neye ihtiyacın var
  1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: adım 1, 1 resimden 1.
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 2, 2 resimden 1. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 2, 2 resimden 2.
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 3, 2 resimden 1. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 3, 2 resimden 2.
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: adım 4, 1 resimden 1.
    • You can locate the volume buttons on one of the longer sides of the tablet.
  5. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 5, 1 resimden 1.
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  6. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 6, 1 resimden 1.
    • Then remove the ribbon cable from the ZIF connector.
  7. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 7, 1 resimden 1.
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  8. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 8, 2 resimden 1. Digital2 Platinum Pad 9 Volume Buttons Replacement: adım 8, 2 resimden 2.
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
Sonuç
David DeMeritt
637 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 98
