Ana içeriğe geç
Digitech XC- 5206 Buttons Replacement
Neye ihtiyacın var
  1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: adım 1, 2 resimden 1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: adım 1, 2 resimden 2.
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Buttons Replacement: adım 2, 3 resimden 1. Digitech XC- 5206 Buttons Replacement: adım 2, 3 resimden 2. Digitech XC- 5206 Buttons Replacement: adım 2, 3 resimden 3.
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Buttons Replacement: adım 3, 1 resimden 1.
    • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
  4. Digitech XC- 5206 Buttons Replacement: adım 4, 3 resimden 1. Digitech XC- 5206 Buttons Replacement: adım 4, 3 resimden 2. Digitech XC- 5206 Buttons Replacement: adım 4, 3 resimden 3.
    • Remove circuit board by pulling straight upwards out of slot.
    • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 151
