Giriş
Dim or black out the annoying blue LED on a Hesh 2 Wireless headset.
Neye ihtiyacın var
On the right speaker, remove the 4 screws shown.
Remove the plastic plate , but be careful not to damage the speaker wires.
On the bottom left of the board, near the power button, are LED0 through LED3. The odd numbered LEDs are blue, and the even numbered LEDs are red.
With the sharpie, carefully mark the tops of the LEDs. Alternatively, if you want to black out the lights entirely, use very small pieces of electrical tape to cover them.
5 farklı kişi bu kılavuzu tamamladı.
4 Yorum
I just put a drop of nail polish in each led. i use deep red. with that color you still have let signal for on/off and low bat.
Buenas tardes mi problema con mis audífonos es que ya no prenden debido a una caída,lo cual se me hace raro ya que al querer prenderlos solo parpadean los led pero ya no se escucha el encendido...
Gracias espero tener respuesta
Quiero identificar que color de cables que van en su lugar tuve un problema y lo abrí todos los cables están despegados así que quiero identificar en que parte va cada uno espero y me puedan ayudar 😅
Good job for documenting this repair, always helpful.
