Ana içeriğe geç
Dim Blue LED on Skullcandy Hesh 2 Wireless
Neye ihtiyacın var
  1. Dim Blue LED on Skullcandy Hesh 2 Wireless, Remove Cushions: adım 1, 1 resimden 1.
    • Remove the cushion from both speakers.
  2. Dim Blue LED on Skullcandy Hesh 2 Wireless, Opening The Speaker: adım 2, 2 resimden 1. Dim Blue LED on Skullcandy Hesh 2 Wireless, Opening The Speaker: adım 2, 2 resimden 2.
    • On the right speaker, remove the 4 screws shown.
    • Remove the plastic plate , but be careful not to damage the speaker wires.
  3. Dim Blue LED on Skullcandy Hesh 2 Wireless, Covering LEDs: adım 3, 1 resimden 1.
    • On the bottom left of the board, near the power button, are LED0 through LED3. The odd numbered LEDs are blue, and the even numbered LEDs are red.
    • With the sharpie, carefully mark the tops of the LEDs. Alternatively, if you want to black out the lights entirely, use very small pieces of electrical tape to cover them.
    • It's a good idea to verify the color of each LED by powering on the headset while it's open.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ian
1.474 İtibar
2 adet Kılavuz yazıldı
Ekip
Kid fixers Kid fixers üyesi
Community
154 Üyeler
291 adet Kılavuz yazıldı
4 Yorum
I just put a drop of nail polish in each led. i use deep red. with that color you still have let signal for on/off and low bat.
Francisco B - Yanıt
Buenas tardes mi problema con mis audífonos es que ya no prenden debido a una caída,lo cual se me hace raro ya que al querer prenderlos solo parpadean los led pero ya no se escucha el encendido...
Gracias espero tener respuesta
Kevin Lujano Torres - Yanıt
Quiero identificar que color de cables que van en su lugar tuve un problema y lo abrí todos los cables están despegados así que quiero identificar en que parte va cada uno espero y me puedan ayudar 😅
Yoni Lizárraga - Yanıt
Good job for documenting this repair, always helpful.
LagaiPhone - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 3,243
