Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
It can be tricky to find all the potential blockages, so this guide will show how to find and then clean all of them.
Neye ihtiyacın var
Locate the dust cup latch and press down.
Pull outwards and up with the handle to remove the cup.
At the bottom of the now vacant dust cup holder, locate the filter assembly and shroud. It is located just above the "Performance Indicator"
Pull up on the latch indicated and remove the shroud.
Use a Phillips #2 Screwdriver to remove the dust cup shroud.
Remove the shroud by sliding it downwards over the dust cup slowly, working it off, being careful not to let it over-extend.
Rinse the filter shroud off in water. Particulates should come off fairly easy, as they should be small. If not, scrub lightly.
Rinse the foam filter off, working the particulates out with water, being careful not to damage the filter.
Run water through the HEPA filter in the opposite direction of the airflow. The water should be hitting the side that the foam filter usually is mounted on.
Place all three items somewhere to dry.
Run water through all the dust cup components, especially the dust collector, removing any lodged particulates or hair.
2 farklı kişi bu kılavuzu tamamladı.
