Ana içeriğe geç
Dis/assembling Eye/Pupil Camera Housing
Neye ihtiyacın var
  1. Dis/assembling Eye/Pupil Camera Housing, Dis/assembling Eye/Pupil Camera Housing: adım 1, 1 resimden 1.
    • First: Eye Camera
    • Remove initial frame (crack off)
  2. Dis/assembling Eye/Pupil Camera Housing: adım 2, 1 resimden 1.
    • Remove 4 screws.
  3. Dis/assembling Eye/Pupil Camera Housing: adım 3, 1 resimden 1.
    • Remove cover to get to the PCB underneath
  4. Dis/assembling Eye/Pupil Camera Housing: adım 4, 1 resimden 1.
    • Remove two screws on the PCB.
  5. Dis/assembling Eye/Pupil Camera Housing: adım 5, 1 resimden 1.
    • Remove PCB from the base plastic piece.
  6. Dis/assembling Eye/Pupil Camera Housing: adım 6, 1 resimden 1.
    • Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
  7. Dis/assembling Eye/Pupil Camera Housing: adım 7, 1 resimden 1.
    • Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
  8. Dis/assembling Eye/Pupil Camera Housing: adım 8, 1 resimden 1.
    • Completed assembly of the eye camera.
  9. Dis/assembling Eye/Pupil Camera Housing, Pupil camera dis/assembly: adım 9, 1 resimden 1.
    • Back of pupil camera is glued on. Remove with flat-head.
  10. Dis/assembling Eye/Pupil Camera Housing: adım 10, 1 resimden 1.
    • Remove the black frame on the front of the pupil camera.
  11. Dis/assembling Eye/Pupil Camera Housing: adım 11, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 11, 2 resimden 2.
    • Once frame is taken off the front, two screws need to be removed.
  12. Dis/assembling Eye/Pupil Camera Housing: adım 12, 1 resimden 1.
    • One screw removed from the back.
  13. Dis/assembling Eye/Pupil Camera Housing: adım 13, 1 resimden 1.
    • Front housing comes off once the screws are removed from the frame.
    • Twist out the silver microphone.
  14. Dis/assembling Eye/Pupil Camera Housing: adım 14, 1 resimden 1.
    • Pull off bottom stand until it breaks off.
  15. Dis/assembling Eye/Pupil Camera Housing: adım 15, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 15, 2 resimden 2.
    • Remove rubber/plastic piece from the bottom
  16. Dis/assembling Eye/Pupil Camera Housing: adım 16, 1 resimden 1.
    • Remove four screws from under the plastic tape (removed from last step).
  17. Dis/assembling Eye/Pupil Camera Housing: adım 17, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 17, 2 resimden 2.
    • Bottom pops off
  18. Dis/assembling Eye/Pupil Camera Housing: adım 18, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 18, 2 resimden 2.
    • Separate the metal frame from the plastic assembly.
    • Avoid the cables
  19. Dis/assembling Eye/Pupil Camera Housing: adım 19, 1 resimden 1.
    • Take out PCB from the plastic housing.
  20. Dis/assembling Eye/Pupil Camera Housing: adım 20, 3 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 20, 3 resimden 2. Dis/assembling Eye/Pupil Camera Housing: adım 20, 3 resimden 3.
    • Remove the rest of the black plastic housing.
  21. Dis/assembling Eye/Pupil Camera Housing: adım 21, 1 resimden 1.
    • Black plastic housing removed
  22. Dis/assembling Eye/Pupil Camera Housing: adım 22, 3 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 22, 3 resimden 2. Dis/assembling Eye/Pupil Camera Housing: adım 22, 3 resimden 3.
    • Continue removing the black plastic housing surrounding the inner PCB.
  23. Dis/assembling Eye/Pupil Camera Housing: adım 23, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 23, 2 resimden 2.
    • PCB removed from the black plastic housing.
  24. Dis/assembling Eye/Pupil Camera Housing: adım 24, 1 resimden 1.
    • Autofocus assembly.
    • Remove two screws from the bottom of the auto-focus PCB.
  25. Dis/assembling Eye/Pupil Camera Housing: adım 25, 1 resimden 1.
    • Unscrew the lens
  26. Dis/assembling Eye/Pupil Camera Housing: adım 26, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 26, 2 resimden 2.
    • Take out the IR filter by using a scalpel for pulling out the lens tape.
  27. Dis/assembling Eye/Pupil Camera Housing: adım 27, 3 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 27, 3 resimden 2. Dis/assembling Eye/Pupil Camera Housing: adım 27, 3 resimden 3.
    • Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
  28. Dis/assembling Eye/Pupil Camera Housing: adım 28, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 28, 2 resimden 2.
    • IR LEDs replaced by SMD LED
    • Soldering required here (at bottom of LED to remove).
  29. Dis/assembling Eye/Pupil Camera Housing: adım 29, 1 resimden 1.
    • SMD LED info: Thick black line is near the positive side of the LED
    • Dark side (dot) is positive side on LED.
  30. Dis/assembling Eye/Pupil Camera Housing: adım 30, 3 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 30, 3 resimden 2. Dis/assembling Eye/Pupil Camera Housing: adım 30, 3 resimden 3.
    • Insert PCB into 3d-printed frame.
  31. Dis/assembling Eye/Pupil Camera Housing: adım 31, 2 resimden 1. Dis/assembling Eye/Pupil Camera Housing: adım 31, 2 resimden 2.
    • Completed assembly.
    • Sugru used for nose/head rest
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Silas
318 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 649
