Ana içeriğe geç
Disassembling 2010-2014 Ford Mustang Center Console
Neye ihtiyacın var
  1. Disassembling 2010-2014 Ford Mustang Center Console, Disassembling 2010-2014 Ford Mustang Center Console: adım 1, 2 resimden 1. Disassembling 2010-2014 Ford Mustang Center Console, Disassembling 2010-2014 Ford Mustang Center Console: adım 1, 2 resimden 2.
    • Open the rear part of the middle console.
  2. Disassembling 2010-2014 Ford Mustang Center Console: adım 2, 2 resimden 1. Disassembling 2010-2014 Ford Mustang Center Console: adım 2, 2 resimden 2.
    • Grip the right side of the console and pull up towards the passenger seat to remove it.
  3. Disassembling 2010-2014 Ford Mustang Center Console: adım 3, 2 resimden 1. Disassembling 2010-2014 Ford Mustang Center Console: adım 3, 2 resimden 2.
    • Locate the two bolts under the air conditioning controls at the bottom of the face plate.
    • Loosen these two bolts with a basic socket wrench suited for 7mm bolts.
  4. Disassembling 2010-2014 Ford Mustang Center Console: adım 4, 2 resimden 1. Disassembling 2010-2014 Ford Mustang Center Console: adım 4, 2 resimden 2.
    • Wedge a spudger or plastic opening tool (in place of the screwdriver shown) under the top of the face plate.
    • Apply pressure until the corners "pop" out of place.
  5. Disassembling 2010-2014 Ford Mustang Center Console: adım 5, 1 resimden 1.
    • Inspect the interior of the center console for damaged wires or other faulty components.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Christopher Pell
251 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G45
5 Üyeler
6 adet Kılavuz yazıldı
4 Yorum
Were can I get that faceplate connector and the connectors for the sterio...I have a 2010 v6 mustang
Zack - Yanıt
I found a replacement but need wire configuration for the 4 wires can anyone help ?
beauxvader -
Try using the correct tool to remove panels...
hotmail1hotmail - Yanıt
The screwdriver is not required. Nor is any other tool at that point. GENTLY pull from the tabs where you removed the screws.
The faceplate will begin to loosen from the bottom up. After pulling out a few inches, push back inward about a half of an inch. This has the effect of a teeter/totter on the remaining top wedge pins. Now grasp the two knobs on the bottom of the panel (fan and temp) and loosen first the left side and then the right side. No real force required at any time and practically falls out. NO SCARS on the trim.
cheers,
dbw -
davidwest805 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 101
Her zaman: 20,269
