Giriş
If your screen has become damaged--cracked, scratched, or more--then it is in need of replacement. This guide will show you how to remove the battery and motherboard in order to access your broken screen.
Neye ihtiyacın var
To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
The motherboard will need to be removed in order to access the screen.
To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
Bir başkası bu kılavuzu tamamladı.
