Ana içeriğe geç
Disassembling APEX AP-GS918 Screen
Neye ihtiyacın var
    1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: adım 1, 3 resimden 1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: adım 1, 3 resimden 2. Disassembling APEX AP-GS918 Screen, Power/Volume Button: adım 1, 3 resimden 3.
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling APEX AP-GS918 Screen: adım 2, 3 resimden 1. Disassembling APEX AP-GS918 Screen: adım 2, 3 resimden 2. Disassembling APEX AP-GS918 Screen: adım 2, 3 resimden 3.
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling APEX AP-GS918 Screen: adım 3, 2 resimden 1. Disassembling APEX AP-GS918 Screen: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling APEX AP-GS918 Screen, Battery: adım 4, 2 resimden 1. Disassembling APEX AP-GS918 Screen, Battery: adım 4, 2 resimden 2.
      • Begin removing the black tape covering the motherboard inside the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling APEX AP-GS918 Screen: adım 5, 1 resimden 1.
      • You will need to desolder the two contact points that connect the battery to the mother board.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling APEX AP-GS918 Screen: adım 6, 2 resimden 1. Disassembling APEX AP-GS918 Screen: adım 6, 2 resimden 2.
      • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
      • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling APEX AP-GS918 Screen, Screen: adım 7, 2 resimden 1. Disassembling APEX AP-GS918 Screen, Screen: adım 7, 2 resimden 2.
      • The motherboard will need to be removed in order to access the screen.
      • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling APEX AP-GS918 Screen: adım 8, 2 resimden 1. Disassembling APEX AP-GS918 Screen: adım 8, 2 resimden 2.
      • To finish removing the motherboard you must release the two data cables holding the screen to it.
      • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
      • You can now remove the data cables from the slots and lift the motherboard out from the device.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling APEX AP-GS918 Screen: adım 9, 2 resimden 1. Disassembling APEX AP-GS918 Screen: adım 9, 2 resimden 2.
      • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling APEX AP-GS918 Screen: adım 10, 1 resimden 1.
      • Pull the thin plastic screen casing apart and you can remove the damaged screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Megan Lozicki
416 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S9G1
3 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 1,009
