Ana içeriğe geç
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
Neye ihtiyacın var
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: adım 1, 2 resimden 1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: adım 1, 2 resimden 2.
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: adım 2, 3 resimden 1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: adım 2, 3 resimden 2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: adım 2, 3 resimden 3.
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: adım 3, 1 resimden 1.
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Efe Guldogan
860 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-23, Meier Fall 2015 USF Tampa, Team 14-23, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G23
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 13,695
