Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Disassembling Acer Aspire 5100 laptop Removing DVD drive
Neye ihtiyacın var
    • Find the sliding tab with a small battery symbol next to it. Push the tab to the left to eject the battery
    • Remove the 4 screws securing the large cover on the upper right hand side.
    • Carefully remove the cover from where the screws were. You will see the fan on the top right corner.
    • Turn over the laptop so the back of it is facing up. There are several components you want to remove. Start with the largest component. Get your screw driver and remove the screws holding the component in place. Then slowly lift off the component to expose the RAM.
    • Use a flathead screw driver to remove the one screw securing the DVD drive.
    • Push out the DVD drive.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
luis
167 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-66, Johann Spring 2010 Cal Poly, Team 18-66, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G66
5 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 2,769
