Neye ihtiyacın var
Looking at the sensor from the bottom, you can see the two tabs/prongs that hold the outer case together.
The internal housing will now be exposed. You can use the two tabs/prongs on this porting to remove that portion of the case.
Next, you can remove the 4 small screws holding the internal components to the outer shell.
