Giriş
Removing the cover of the Apple IIc is the precursor to any repair on a computer and it allows you to view the eternal workings of this device.
  1. Remove the six 19 mm long screws with a #2 Phillips head screwdriver. Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Release the catch by pushing it in using a plastic opening tool. The catch is off-center, but in line with the middle of the speaker underneath.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove. Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  5. Lift the handle straight up to remove. Lift the handle straight up to remove.
    • Lift the handle straight up to remove.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Alexandria Weinberg
538 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G23
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - Yanıt
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 9
Son 30 Gün: 63
Her zaman: 5,773
