Ana içeriğe geç
Disassembling Apple IIc Cover
Neye ihtiyacın var
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: adım 1, 2 resimden 1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: adım 1, 2 resimden 2.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Apple IIc Cover: adım 2, 2 resimden 1. Disassembling Apple IIc Cover: adım 2, 2 resimden 2.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Apple IIc Cover: adım 3, 2 resimden 1. Disassembling Apple IIc Cover: adım 3, 2 resimden 2.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Apple IIc Cover: adım 4, 2 resimden 1. Disassembling Apple IIc Cover: adım 4, 2 resimden 2.
    • Lift the handle straight up to remove.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Alexandria Weinberg
601 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G23
4 Üyeler
20 adet Kılavuz yazıldı
3Kılavuz Yorumları
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - Yanıt Paylaş
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III - Yanıt Paylaş
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 85
Her zaman: 11,433
