Ana içeriğe geç
Disassembling Apple IIc Cover
Neye ihtiyacın var
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: adım 1, 2 resimden 1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: adım 1, 2 resimden 2.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Disassembling Apple IIc Cover: adım 2, 2 resimden 1. Disassembling Apple IIc Cover: adım 2, 2 resimden 2.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Disassembling Apple IIc Cover: adım 3, 2 resimden 1. Disassembling Apple IIc Cover: adım 3, 2 resimden 2.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    This step is wrong. The ports cover should be removed with a plastic disassembly tool first. Failure to do this will lead to a set of broken plastic hooks.
    cybernesto - Yanıt
  4. Disassembling Apple IIc Cover: adım 4, 2 resimden 1. Disassembling Apple IIc Cover: adım 4, 2 resimden 2.
    • Lift the handle straight up to remove.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Alexandria Weinberg
601 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G23
4 Üyeler
13 adet Kılavuz yazıldı
3 Yorum
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - Yanıt
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III -
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 59
Son 30 gün: 93
Her zaman: 9,621
