Ana içeriğe geç
Disassembling Arnova 7K G3 Logic Board Ribbon Connectors
Neye ihtiyacın var
  1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: adım 1, 3 resimden 1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: adım 1, 3 resimden 2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: adım 1, 3 resimden 3.
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 2, 2 resimden 1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 2, 2 resimden 2.
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 3, 1 resimden 1.
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 4, 2 resimden 1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 4, 2 resimden 2.
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 5, 3 resimden 1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 5, 3 resimden 2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 5, 3 resimden 3.
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 6, 3 resimden 1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 6, 3 resimden 2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: adım 6, 3 resimden 3.
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
Sonuç
Kue
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-2, Lauer Spring 2015 Michigan Tech, Team 1-2, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G2
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 298
