Giriş
How to disassemble the charger unit.
  1. Slide the plug to release from the transformer unit
    • Slide the plug to release from the transformer unit
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
    • Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
  4. Once the lid comes off you can slide out the internals.
    • Once the lid comes off you can slide out the internals.
Sonuç
2 başka kişi bu kılavuzu tamamladı.
ehfb
61 İtibar
1 Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 6
Son 30 Gün: 31
Her zaman: 3,824
