Ana içeriğe geç
Disassembling Asus W2W-A1 Front Panel
Neye ihtiyacın var
  1. Disassembling Asus W2W-A1 Front Panel, Keyboard: adım 1, 3 resimden 1. Disassembling Asus W2W-A1 Front Panel, Keyboard: adım 1, 3 resimden 2. Disassembling Asus W2W-A1 Front Panel, Keyboard: adım 1, 3 resimden 3.
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Disassembling Asus W2W-A1 Front Panel: adım 2, 1 resimden 1.
    • Remove the panel above the keyboard with a plastic spudger.
  3. Disassembling Asus W2W-A1 Front Panel: adım 3, 1 resimden 1.
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Disassembling Asus W2W-A1 Front Panel: adım 4, 2 resimden 1. Disassembling Asus W2W-A1 Front Panel: adım 4, 2 resimden 2.
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
  5. Disassembling Asus W2W-A1 Front Panel, Front Panel: adım 5, 1 resimden 1.
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
Sonuç
Nolan Schock
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G29
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 44
Her zaman: 567
