Ana içeriğe geç
Disassembling Asus W2W-A1 Protective Cover
Neye ihtiyacın var
  1. Disassembling Asus W2W-A1 Protective Cover, Keyboard: adım 1, 3 resimden 1. Disassembling Asus W2W-A1 Protective Cover, Keyboard: adım 1, 3 resimden 2. Disassembling Asus W2W-A1 Protective Cover, Keyboard: adım 1, 3 resimden 3.
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Asus W2W-A1 Protective Cover: adım 2, 1 resimden 1.
    • Remove the panel above the keyboard with a plastic spudger.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Asus W2W-A1 Protective Cover: adım 3, 1 resimden 1.
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Asus W2W-A1 Protective Cover: adım 4, 2 resimden 1. Disassembling Asus W2W-A1 Protective Cover: adım 4, 2 resimden 2.
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Asus W2W-A1 Protective Cover, Front Panel: adım 5, 1 resimden 1.
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Asus W2W-A1 Protective Cover, Touchpad: adım 6, 2 resimden 1. Disassembling Asus W2W-A1 Protective Cover, Touchpad: adım 6, 2 resimden 2.
    • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Asus W2W-A1 Protective Cover: adım 7, 1 resimden 1.
    • Gently pull the ribbon cable out of its socket attached to the touchpad.
    • You are now able to remove the touchpad.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Asus W2W-A1 Protective Cover, Protective Cover: adım 8, 1 resimden 1.
    • Unscrew the 3 13 mm Phillips screws on the surface of the panel.
    • Unscrew the 4 mm Phillips screw beneath the panel.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Asus W2W-A1 Protective Cover: adım 9, 3 resimden 1. Disassembling Asus W2W-A1 Protective Cover: adım 9, 3 resimden 2. Disassembling Asus W2W-A1 Protective Cover: adım 9, 3 resimden 3.
    • There are many different types of screws in this step so make sure to arrange the screws by their different sizes.
    • Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
    • Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
    • Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
    • Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
    • Unscrew the 5mm Phillips head screw that lies just above the D screw.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Asus W2W-A1 Protective Cover: adım 10, 1 resimden 1.
    • Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
    • After finishing this step, flip the laptop over.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling Asus W2W-A1 Protective Cover: adım 11, 1 resimden 1.
    • Everything should now be loose enough for you to start removing the panel.
    • Do not fully remove the panel, for there are still ribbons attached on the inside.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling Asus W2W-A1 Protective Cover: adım 12, 1 resimden 1.
    • Carefully remove the ribbons from the base.
    • Then you can lift the panel to access the components beneath.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Nolan Schock
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G29
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 688
