Giriş
As a first step to clean, maintain, or install new parts (excluding the blender blades) for the Black and Decker BL3000S the blender base must be taken apart. This guide will provide step by step instructions of how to perform this task.
  1. Before disassembling the blender base, make sure the blender disconnected from any power outlet. Lift the jar straight up from the base without tilting the jar.
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver. This provides access to the base screws beneath.
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  5. Remove the following screws that secure the top and  bottom halves of the base.
    • Remove the following screws that secure the top and bottom halves of the base.
      • One 1/4 Phillips screw
      • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  6. Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew
170 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G34
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 11
Son 30 Gün: 58
Her zaman: 3,936
