Ana içeriğe geç
Disassembling Blackberry 7105t Full Dissassembly
Neye ihtiyacın var
  1. Disassembling Blackberry 7105t Full Dissassembly, Blackberry 7105t Disassembly: adım 1, 1 resimden 1.
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Disassembling Blackberry 7105t Full Dissassembly: adım 2, 1 resimden 1.
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Disassembling Blackberry 7105t Full Dissassembly: adım 3, 1 resimden 1.
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Disassembling Blackberry 7105t Full Dissassembly: adım 4, 1 resimden 1.
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Disassembling Blackberry 7105t Full Dissassembly: adım 5, 3 resimden 1. Disassembling Blackberry 7105t Full Dissassembly: adım 5, 3 resimden 2. Disassembling Blackberry 7105t Full Dissassembly: adım 5, 3 resimden 3.
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Disassembling Blackberry 7105t Full Dissassembly: adım 6, 1 resimden 1.
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Disassembling Blackberry 7105t Full Dissassembly: adım 7, 1 resimden 1.
    • The black battery casing and logic board can now be separated for the following steps.
  8. Disassembling Blackberry 7105t Full Dissassembly, battery contact: adım 8, 1 resimden 1.
    • With the speaker facing you, place your fingers on the gold battery connector.
    • Pull upwards and release the battery connector from the black body piece.
  9. Disassembling Blackberry 7105t Full Dissassembly, Speaker: adım 9, 2 resimden 1. Disassembling Blackberry 7105t Full Dissassembly, Speaker: adım 9, 2 resimden 2.
    • With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
    • Place the three clips in plastic bag and set aside.
    • Once clips are removed, you will have full access to remove the speaker.
  10. Disassembling Blackberry 7105t Full Dissassembly, Second Disassembly: adım 10, 1 resimden 1.
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
  11. Disassembling Blackberry 7105t Full Dissassembly, Keyboard: adım 11, 2 resimden 1. Disassembling Blackberry 7105t Full Dissassembly, Keyboard: adım 11, 2 resimden 2.
    • Use a plastic opening tool to lift up the two black clips indicated in the picture.
    • Hold on to the keyboard while unfastening the clips.
    • The keyboard will detach once the clips are unfastened.
  12. Disassembling Blackberry 7105t Full Dissassembly, LCD: adım 12, 1 resimden 1.
    • With the screen facing you, you will be able to see a small grey plastic clip.
    • Use a plastic opening tool to unfasten the clip as shown.
  13. Disassembling Blackberry 7105t Full Dissassembly: adım 13, 2 resimden 1. Disassembling Blackberry 7105t Full Dissassembly: adım 13, 2 resimden 2.
    • Flip the logic board over to the other side.
    • Use a plastic opening tool unclip the top two clips shown in red, and then the bottom two clips. This releases the screen.
    • Flip logic board over and remove screen.
    • Make sure to hold the screen, it could fall after being unclipped.
  14. Disassembling Blackberry 7105t Full Dissassembly: adım 14, 1 resimden 1.
    • NOTE: If you are not replacing the LCD screen, move on to the next step.
    • After removing the original screen, keep the logic board facing you the way it was.
    • Take the new screen and slip the flexible piece of connecting circuitry under the grey plastic flap that you pried up in step 10.
    • Handle the screen carefully as it is fragile.
    • Push it gently but firmly until it does not move any further to the left, then close the grey flap.
    • After this, the screen can be pushed down and clicked back into place.
    • To reassemble the phone, reverse instructions.
  15. Disassembling Blackberry 7105t Full Dissassembly, Full Dissassembly: adım 15, 3 resimden 1. Disassembling Blackberry 7105t Full Dissassembly, Full Dissassembly: adım 15, 3 resimden 2. Disassembling Blackberry 7105t Full Dissassembly, Full Dissassembly: adım 15, 3 resimden 3.
    • Use a spudger or your fingernails to push outwards against one of the black clips. The plastic end cap should fall easily away.
  16. Disassembling Blackberry 7105t Full Dissassembly: adım 16, 1 resimden 1.
    • Here are all the parts of your Blackberry 7105t, fully disassembled.
  17. Disassembling Blackberry 7105t Full Dissassembly: adım 17, 1 resimden 1.
    • Here are all the pieces, flipped over.
Sonuç
CeeJay
19 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009 üyesi
CPSU-REGAN-F09S9G17
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 2,202
