Ana içeriğe geç
Disassembling Breville BKC600XL Coffee Brewer Head
Neye ihtiyacın var
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: adım 1, 3 resimden 1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: adım 1, 3 resimden 2. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: adım 1, 3 resimden 3.
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: adım 2, 1 resimden 1.
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: adım 3, 3 resimden 1. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: adım 3, 3 resimden 2. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: adım 3, 3 resimden 3.
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Antonio
120 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G3
4 Üyeler
2 Yorum
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Yanıt
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 4,141
