Ana içeriğe geç
Disassembling Canon EOS Rebel XS Battery Door
Neye ihtiyacın var
  1. Disassembling Canon EOS Rebel XS Battery Door, Latch Side Cover: adım 1, 1 resimden 1.
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Battery Door: adım 2, 1 resimden 1.
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Battery Door, Disassembling Canon EOS Rebel XS Front Cover: adım 3, 1 resimden 1.
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Battery Door: adım 4, 1 resimden 1.
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Battery Door, Grip: adım 5, 1 resimden 1.
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Disassembling Canon EOS Rebel XS Battery Door: adım 6, 1 resimden 1.
    • Use your fingertip to pry off the external shutter port cover.
  7. Disassembling Canon EOS Rebel XS Battery Door: adım 7, 1 resimden 1.
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Disassembling Canon EOS Rebel XS Battery Door: adım 8, 3 resimden 1. Disassembling Canon EOS Rebel XS Battery Door: adım 8, 3 resimden 2. Disassembling Canon EOS Rebel XS Battery Door: adım 8, 3 resimden 3.
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Disassembling Canon EOS Rebel XS Battery Door: adım 9, 1 resimden 1.
    • Once the grip is loose, use your fingers to remove it from the camera.
  10. Disassembling Canon EOS Rebel XS Battery Door, Battery Door: adım 10, 1 resimden 1.
    • Remove the 4.8mm (.19in) long silver screw from the inside of the grip.
  11. Disassembling Canon EOS Rebel XS Battery Door: adım 11, 2 resimden 1. Disassembling Canon EOS Rebel XS Battery Door: adım 11, 2 resimden 2.
    • Remove the hinge of the battery door from the inside of the grip.
    • Our sample camera's battery door was broken off of its hinge. Picture two shows an example of a battery door that is not broken.
Sonuç
Daniel Bussone
1.251 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G41
2 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 4,954
