Ana içeriğe geç
Disassembling Canon EOS Rebel XS Front Cover
Neye ihtiyacın var
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: adım 1, 1 resimden 1.
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Front Cover: adım 2, 1 resimden 1.
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: adım 3, 1 resimden 1.
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Front Cover: adım 4, 1 resimden 1.
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Bussone
1.251 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G41
2 Üyeler
21 adet Kılavuz yazıldı
2 Yorum
This should be labelled: Easy.
tjt263 - Yanıt
Okay, there are several steps missing.
tjt263 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 5,275
