Ana içeriğe geç
Disassembling Canon Pixma MP480 Rear and Side Panel
Neye ihtiyacın var
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: adım 1, 2 resimden 1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: adım 1, 2 resimden 2.
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 2, 1 resimden 1.
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 3, 1 resimden 1.
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 4, 2 resimden 1. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 4, 2 resimden 2.
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 5, 2 resimden 1. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 5, 2 resimden 2.
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 6, 2 resimden 1. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 6, 2 resimden 2.
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 7, 2 resimden 1. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 7, 2 resimden 2.
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 8, 2 resimden 1. Disassembling Canon Pixma MP480 Rear and Side Panel: adım 8, 2 resimden 2.
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kevin Cole
116 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 19-41, Regan Winter 2013 Cal Poly, Team 19-41, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G41
4 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Good job!!!!
lhitvietnam - Yanıt
Where is the rest of disassembly?
bill roberts - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 21,329
