Ana içeriğe geç
Disassembling Canon PowerShot A590 IS Front Cover
Neye ihtiyacın var
  1. Disassembling Canon PowerShot A590 IS Front Cover, Batteries: adım 1, 2 resimden 1. Disassembling Canon PowerShot A590 IS Front Cover, Batteries: adım 1, 2 resimden 2.
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Disassembling Canon PowerShot A590 IS Front Cover: adım 2, 1 resimden 1.
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Disassembling Canon PowerShot A590 IS Front Cover: adım 3, 1 resimden 1.
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Disassembling Canon PowerShot A590 IS Front Cover, Back Cover: adım 4, 1 resimden 1.
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Disassembling Canon PowerShot A590 IS Front Cover: adım 5, 1 resimden 1.
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Disassembling Canon PowerShot A590 IS Front Cover: adım 6, 1 resimden 1.
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Disassembling Canon PowerShot A590 IS Front Cover: adım 7, 1 resimden 1.
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
  8. Disassembling Canon PowerShot A590 IS Front Cover, Remove Lens Cover: adım 8, 1 resimden 1.
    • Press and hold down the button shown in the blue circle.
    • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
  9. Disassembling Canon PowerShot A590 IS Front Cover, Remove Front Cover: adım 9, 2 resimden 1. Disassembling Canon PowerShot A590 IS Front Cover, Remove Front Cover: adım 9, 2 resimden 2.
    • Remove the front cover of the camera.
    • This may require a bit of force.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Zach
284 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G19
4 Üyeler
14 adet Kılavuz yazıldı
3 Yorum
The photos do not show a camera strap, and the instructions don't mention it. Before starting disassembly, I advise removing the camera strap. It make it easier to remove and re-attach the back cover.
jwoconnor - Yanıt
A handy guide. I had an A590IS with a broken battery door latch on the camera body, and I managed to obtain a dead A590IS with a fully intact latch for free. So using this guide I swapped the body shells over! All fixed and working again!
brianinnes81 - Yanıt
l cannot get an answer to my question on why my Canon A590 will not power on.
burks817 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 51
Her zaman: 14,955
