Ana içeriğe geç
Disassembling Canon PowerShot S50 Outer Casing
Neye ihtiyacın var
  1. Disassembling Canon PowerShot S50 Outer Casing, Battery: adım 1, 2 resimden 1. Disassembling Canon PowerShot S50 Outer Casing, Battery: adım 1, 2 resimden 2.
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Disassembling Canon PowerShot S50 Outer Casing: adım 2, 1 resimden 1.
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Disassembling Canon PowerShot S50 Outer Casing: adım 3, 2 resimden 1. Disassembling Canon PowerShot S50 Outer Casing: adım 3, 2 resimden 2.
    • Holding the edges, slide out the battery.
  4. Disassembling Canon PowerShot S50 Outer Casing, Front Panel/Battery Door: adım 4, 1 resimden 1.
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Disassembling Canon PowerShot S50 Outer Casing: adım 5, 1 resimden 1.
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Disassembling Canon PowerShot S50 Outer Casing: adım 6, 1 resimden 1.
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Disassembling Canon PowerShot S50 Outer Casing: adım 7, 1 resimden 1.
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Disassembling Canon PowerShot S50 Outer Casing: adım 8, 1 resimden 1.
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Disassembling Canon PowerShot S50 Outer Casing: adım 9, 1 resimden 1.
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Disassembling Canon PowerShot S50 Outer Casing: adım 10, 1 resimden 1.
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Disassembling Canon PowerShot S50 Outer Casing: adım 11, 1 resimden 1.
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Disassembling Canon PowerShot S50 Outer Casing: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Disassembling Canon PowerShot S50 Outer Casing: adım 13, 1 resimden 1.
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
  14. Disassembling Canon PowerShot S50 Outer Casing, Outer Casing: adım 14, 1 resimden 1.
    • Using a spudger, gently separate the back panel from the rest of the camera and remove it.
Sonuç
Karim
24 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-34, Maness Spring 2012 Cal Poly, Team 7-34, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G34
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 1,811
