Ana içeriğe geç
Disassembling Canon PowerShot SD1100 IS AV port and Logic board
Neye ihtiyacın var
  1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, Front and Rear Cover: adım 1, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, Front and Rear Cover: adım 1, 2 resimden 2.
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 2, 3 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 2, 3 resimden 2. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 2, 3 resimden 3.
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 3, 3 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 3, 3 resimden 2. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 3, 3 resimden 3.
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 4, 1 resimden 1.
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, LCD screen: adım 5, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, LCD screen: adım 5, 2 resimden 2.
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 6, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 6, 2 resimden 2.
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 7, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 7, 2 resimden 2.
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 9, 3 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 9, 3 resimden 2. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 9, 3 resimden 3.
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 10, 1 resimden 1.
    • The LCD screen should now be removed.
  11. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, Flash Assembly: adım 11, 1 resimden 1.
    • Remove the screw located on the side of the camera (0.072 in).
  12. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 12, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 12, 2 resimden 2.
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  13. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 13, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 13, 2 resimden 2.
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  14. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 14, 1 resimden 1.
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
  15. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 15, 1 resimden 1.
    • The capacitor should now be removed.
  16. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, Camera Lens: adım 16, 1 resimden 1.
    • Remove 4 screws from silver plate (0.106 in).
  17. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 17, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 17, 2 resimden 2.
    • Use spudger to lift the second lens ribbon.
    • Remember the first ribbon was removed while taking out the flash assembly.
  18. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 18, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 18, 2 resimden 2.
    • Use spudger to carefully lift the LED light off the upper-left corner of the lens.
  19. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 19, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 19, 2 resimden 2.
    • Remove the lens.
  20. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 20, 1 resimden 1.
    • The camera lens should now be removed.
  21. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, AV port and Logic board: adım 21, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board, AV port and Logic board: adım 21, 2 resimden 2.
    • Remove screw from top-right of logic board (0.102 in).
    • Remove screw on the silver plate (0.102 in).
  22. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 22, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 22, 2 resimden 2.
    • Remove screw from bottom-right of logic board board (0.102 in).
    • The tripod connector can now be removed.
  23. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 23, 1 resimden 1.
    • Remove screw (0.102 in) from the left side of the logic board.
  24. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 24, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 24, 2 resimden 2.
    • Using the spudger, disconnect the ribbon cable located on the top of the logic board.
  25. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 25, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 25, 2 resimden 2.
    • The logic board may now be removed from the frame.
  26. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 26, 3 resimden 1. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 26, 3 resimden 2. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 26, 3 resimden 3.
    • Remove the remaining screw (0.102 in) located on the camera strap piece.
    • The camera strap piece and the av port/battery/memory card assembly can now be removed.
  27. Disassembling Canon PowerShot SD1100 IS AV port and Logic board: adım 27, 1 resimden 1.
    • This is the final product.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler Grossheim
1.524 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G32
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
The lens seems to be misaligned with the hole on the front frame. Has anyone had this problem? If so can you please let me know if it's something simple I'm doing or not doing. Thank you.
David - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 28
Her zaman: 2,768
