Ana içeriğe geç
Disassembling Canon PowerShot SD1100 IS Front and Rear Cover
Neye ihtiyacın var
  1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: adım 1, 2 resimden 1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: adım 1, 2 resimden 2.
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: adım 2, 3 resimden 1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: adım 2, 3 resimden 2. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: adım 2, 3 resimden 3.
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: adım 3, 3 resimden 1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: adım 3, 3 resimden 2. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: adım 3, 3 resimden 3.
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: adım 4, 1 resimden 1.
    • The cases should now be removed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler Grossheim
1.524 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G32
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 3,482
