Ana içeriğe geç
Disassembling Canon PowerShot SD800 IS Front Cover
Neye ihtiyacın var
  1. Disassembling Canon PowerShot SD800 IS Front Cover, Back Cover: adım 1, 1 resimden 1.
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS Front Cover: adım 2, 1 resimden 1.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS Front Cover: adım 3, 1 resimden 1.
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS Front Cover: adım 4, 1 resimden 1.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS Front Cover, Front Cover: adım 5, 1 resimden 1.
    • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  6. Disassembling Canon PowerShot SD800 IS Front Cover: adım 6, 1 resimden 1.
    • Remove one 2.25mm screw on the bottom of the camera.
  7. Disassembling Canon PowerShot SD800 IS Front Cover: adım 7, 1 resimden 1.
    • Pull off the front cover.
Sonuç
Jeremy Rabaino
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-9, Maness Fall 2010 Cal Poly, Team 20-9, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G9
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 2,542
