Giriş
The LCD display can be removed and replaced if it is cracked or broken.
Neye ihtiyacın var
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
Disconnect the ribbons that connect the screen to the camera.
Lift the screen off.
