Ana içeriğe geç
Disassembling Canon Powershot SD880 Logic Board
Neye ihtiyacın var
    1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: adım 1, 3 resimden 1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: adım 1, 3 resimden 2. Disassembling Canon Powershot SD880 Logic Board, Back Cover: adım 1, 3 resimden 3.
      • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
      • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
      • One screw will be located under the rubber USB flap.
      • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Slowly pull the back cover off of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Canon Powershot SD880 Logic Board, Front Cover: adım 2, 3 resimden 1. Disassembling Canon Powershot SD880 Logic Board, Front Cover: adım 2, 3 resimden 2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: adım 2, 3 resimden 3.
      • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
      • The two screws on the other side of the camera were already removed when the back cover was taken off.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Canon Powershot SD880 Logic Board, Top Panel: adım 3, 2 resimden 1. Disassembling Canon Powershot SD880 Logic Board, Top Panel: adım 3, 2 resimden 2.
      • Unplug the green and white plugs that connect the top panel to the top of the logic board.
      • Dislodge the tab above the lens.
      • Dislodge the tab at the back.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Canon Powershot SD880 Logic Board, Logic Board: adım 4, 1 resimden 1.
      • Remove 2 screws(1.75mm) using a screwdriver.
      • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Canon Powershot SD880 Logic Board: adım 5, 2 resimden 1. Disassembling Canon Powershot SD880 Logic Board: adım 5, 2 resimden 2.
      • Remove the newly exposed screw(1.75mm) with screwdriver.
      • Unhinge the black tab to slide out the ribbon.
      • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Juan Miguel
104 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G3
5 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 2,476
