Ana içeriğe geç
Disassembling Canon Powershot SD880 Logic Board
Neye ihtiyacın var
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: adım 1, 3 resimden 1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: adım 1, 3 resimden 2. Disassembling Canon Powershot SD880 Logic Board, Back Cover: adım 1, 3 resimden 3.
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: adım 2, 3 resimden 1. Disassembling Canon Powershot SD880 Logic Board, Front Cover: adım 2, 3 resimden 2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: adım 2, 3 resimden 3.
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: adım 3, 2 resimden 1. Disassembling Canon Powershot SD880 Logic Board, Top Panel: adım 3, 2 resimden 2.
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: adım 4, 1 resimden 1.
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: adım 5, 2 resimden 1. Disassembling Canon Powershot SD880 Logic Board: adım 5, 2 resimden 2.
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
Sonuç
Juan Miguel
104 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G3
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 29
Her zaman: 2,096
