Ana içeriğe geç
Disassembling Casio CZ-1000 Backplate
Neye ihtiyacın var
  1. Disassembling Casio CZ-1000 Backplate, Backplate: adım 1, 2 resimden 1. Disassembling Casio CZ-1000 Backplate, Backplate: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Disassembling Casio CZ-1000 Backplate: adım 2, 3 resimden 1. Disassembling Casio CZ-1000 Backplate: adım 2, 3 resimden 2. Disassembling Casio CZ-1000 Backplate: adım 2, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Disassembling Casio CZ-1000 Backplate: adım 3, 3 resimden 1. Disassembling Casio CZ-1000 Backplate: adım 3, 3 resimden 2. Disassembling Casio CZ-1000 Backplate: adım 3, 3 resimden 3.
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
Sonuç
Jace Alexander
181 İtibar
2 adet Kılavuz yazıldı
Ekip
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S60G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 119
