Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove all four screws on the side of camera with speaker.
    • Remove all four screws on the side of camera with speaker.
  2. Remove all four screws from side of camera with wristband attachment.
    • Remove all four screws from side of camera with wristband attachment.
  3. Remove all four screws on bottom of camera.
    • Remove all four screws on bottom of camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
  4. Once all screws have been removed, gently pry open bottom casing. With tweezers, carefully remove ribbon from LCD screen. Set bottom casing aside.
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
  5. Pry apart the top casing using tweezers. Set the top casing aside.
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Logan
311 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G38
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 2,860
