Giriş
This guide shows you how to open the Casio Exilim EX-Z850's outer casing and access the camera's internal components. This may be necessary to replace parts of your camera.
Neye ihtiyacın var
Remove all four screws on the camera's side using a Phillips #00 screwdriver.
Remove all four screws on the opposite side of the camera using the same screwdriver.
Remove all four screws on the bottom of the camera using the same screwdriver.
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
2 farklı kişi bu kılavuzu tamamladı.
