Ana içeriğe geç
Disassembling Chef's Choice M115 Case
Neye ihtiyacın var
    1. Disassembling Chef's Choice M115 Case, Case: adım 1, 2 resimden 1. Disassembling Chef's Choice M115 Case, Case: adım 1, 2 resimden 2.
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Chef's Choice M115 Case: adım 2, 1 resimden 1.
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Chef's Choice M115 Case: adım 3, 1 resimden 1.
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling Chef's Choice M115 Case: adım 4, 1 resimden 1.
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Zachary Grounds
592 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G3
5 Üyeler
33 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Yanıt Paylaş
Thank you. I have the M120 which I believe is similar. Only the three deeply recessed screws need to be removed to take the case apart. The others hold internal components in place.
John Slater - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 70
Her zaman: 2,495
