Ana içeriğe geç
Disassembling Compaq Mini 110 Fan
Neye ihtiyacın var
  1. Disassembling Compaq Mini 110 Fan, Battery: adım 1, 2 resimden 1. Disassembling Compaq Mini 110 Fan, Battery: adım 1, 2 resimden 2.
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Compaq Mini 110 Fan: adım 2, 3 resimden 1. Disassembling Compaq Mini 110 Fan: adım 2, 3 resimden 2. Disassembling Compaq Mini 110 Fan: adım 2, 3 resimden 3.
    • Push both tabs inward simultaneously and slide the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Compaq Mini 110 Fan, RAM: adım 3, 2 resimden 1. Disassembling Compaq Mini 110 Fan, RAM: adım 3, 2 resimden 2.
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Compaq Mini 110 Fan: adım 4, 1 resimden 1.
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Compaq Mini 110 Fan, Keyboard: adım 5, 2 resimden 1. Disassembling Compaq Mini 110 Fan, Keyboard: adım 5, 2 resimden 2.
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Compaq Mini 110 Fan: adım 6, 2 resimden 1. Disassembling Compaq Mini 110 Fan: adım 6, 2 resimden 2.
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Compaq Mini 110 Fan: adım 7, 2 resimden 1. Disassembling Compaq Mini 110 Fan: adım 7, 2 resimden 2.
    • Unscrew the screw for the bottom case located in the RAM compartment.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Compaq Mini 110 Fan: adım 8, 2 resimden 1. Disassembling Compaq Mini 110 Fan: adım 8, 2 resimden 2.
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Compaq Mini 110 Fan, Top Cover: adım 9, 1 resimden 1.
    • Remove the eight screws that are from the plastic top cover.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Compaq Mini 110 Fan: adım 10, 3 resimden 1. Disassembling Compaq Mini 110 Fan: adım 10, 3 resimden 2. Disassembling Compaq Mini 110 Fan: adım 10, 3 resimden 3.
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling Compaq Mini 110 Fan: adım 11, 2 resimden 1. Disassembling Compaq Mini 110 Fan: adım 11, 2 resimden 2.
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling Compaq Mini 110 Fan, Hard Drive: adım 12, 1 resimden 1.
    • Remove the three screws holding the panel in place.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling Compaq Mini 110 Fan: adım 13, 2 resimden 1. Disassembling Compaq Mini 110 Fan: adım 13, 2 resimden 2.
    • Pull up on the tab to remove the hard drive.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling Compaq Mini 110 Fan, Fan: adım 14, 2 resimden 1. Disassembling Compaq Mini 110 Fan, Fan: adım 14, 2 resimden 2.
    • Remove the two screws holding the fan in place.
    • There is still a cable attached to the fan so be sure to pull that out as well.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
alea
1.429 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-2, Maness Fall 2010 Cal Poly, Team 22-2, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G2
6 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 6,848
