Giriş
The ZEN's case is held together with 8 snaps. The front half has the snaps, and the rear half is just a plastic shell.
You will need at least two thin flat-head screwdrivers (or spudgers or whatever), a 00 phillips screwdriver (that's very small, in case you don't know your sizes) and a low-heat soldering iron. You'll need medium-level soldering skills for this.
To put it back together, just reverse the steps. The case snaps back together nicely.
Parçalar
Hiçbir parça belirtilmedi.
Here's the beast we'll be dissecting. It's a rare 32GB version that's been having some white-screen issues (if you haven't heard, that's a common issue).
Now is the time to consider whether you want to risk destroying your ZEN. The risk is small if you do it right, but remember this: you're choosing to open it. If you break it, it's your fault. Don't be dumb, don't force things. Use your brain.
Find the left side of the ZEN. You can see in the picture that I learned by trial & error how to open my ZEN. If you do it right, you won't leave those gouge marks on the case.
The red rectangles indicate where the tabs are inside the case. They are 0.5" in from the outer edge.
Insert one thin screwdriver in the seam of the case right over the tab (red rectangles, remember?). Pry upward (gently!), forcing the lower half of the shell to flex outward. See pics 2 & 3.
I found it easier to use the big blue opening tool to do what you normally shouldn't do and enter the device from the (empty) sd card slot, pulling the case upwards by carefully using the prying tool as a lever at that point. One of the nearby tabs will pop open and you can slide a prying tool around the upper side of the player. It's hard to work from there to get around the corners; I've only had success by inserting multiple prying tools nearby, forcing the case up until I was able to press one into the tiny opening around the corner where it released one of the side tabs. Same procedure as before and you'll be able to work around the lower side.
In my opinion it's almost impossible to not damage the case which shouldn't be an issue anyway if you bought the rubber protection "sleeve" back in the day.
If you have fingernails in good condition and don’t eat them away to nothing, I find that they work very well.
Once you have the first screwdriver worked in (don't push it in very far, there's a battery close to there), use the other screwdriver to work open the second tab. You'll want both screwdrivers in the ZEN at the same time, like in picture 1. You'll notice that the bottom shell has started to separate.
Remove one of the drivers, trying not to let the case snap back together. Move it to the side (bottom or top) that is closer to the side that still has its driver stuck in. Locate the tab closest to the corner (red rectangle again), 0.5" in again. Free this tab, and hold the corner so that it stays open like in pic. 2.
Release the other two tabs (marked in orange) in the same manner. They are 0.5" and 1.3" from the usb-port side. DO NOT TRY TO SEPARATE THE USB-PORT SIDE. There are different tabs holding it in, so we need to release the three other sides first.
In the 3rd pic, you can see one of the actual tabs inside (far left rectangle). It's 0.5" in from the left side, and the others are 1.9" and 0.5" from the usb-port side. Release all these tabs (8 tabs in total).
Open the case by lifting the non usb-port side slightly, then sliding the bottom shell towards the usb-port (see pics 1 & 2).
In pic 3, we can see the horizontal pins (red circles) that hold the usb-port side of the case on. Those are why we have to open the case on 3 sides and slide it off.
The blue square indicates the two wires that connect the button board to the main board. The yellow square indicates the battery wires, which are hidden under the RF shield.
Ideally we would disconnect the battery first. Unfortunately, the battery wires are soldered to the board underneath the RF shield. The first step is to remove the shield. It is soldered onto the main board in 4 places, circled in red.
Using a low-heat, fine-tip soldering iron, carefully heat up the pads and lift the shield off the board. Be very careful not to splatter or spread any solder on the board itself.
The shield wraps around the LCD connector (upper left), but is only tucked in. It may be carefully pulled out, then placed aside.
Now we'll pop open the LCD connector. The black rectangle on the OPPOSITE side of the ribbon cable flips up, rotating in the middle of the connector. Use your fingernail to gently flip it open, then pull the connector out.
The next thing to do is to disconnect the battery. Using your soldering iron, heat up the positive pad (circled in red in pic 3, surrounded by a white square on the actual PCB). Pull the wire away from the board and wrap it in electrical tape to prevent shorts. Be careful to only touch one pad at a time with the iron, as you may create a short if you touch multiple pads.
Desolder both battery wires and both button wires (red rectangles). Gently bend them away from the board, being careful not to pull on them.
Unscrew the 4 screws holding the main board down (blue circles). Slide the board to the right slightly, then lift it out. Place the screws in a pile designated "A". There are two different kinds of screws, as seen later.
There are four more "A" screws on the sides of the device, circled in green. Remove them and put them in the "A" pile.
The two screws circled in yellow are type "B" screws. Remove them and put them in a separate pile.
The 3rd pic shows the difference between "A" screws (left) and "B" screws (right). There are 8 "A" and 2 "B".
Now the metal battery tray can be lifted out of the body. Nothing tricky here, just pull gently.
The LCD is now accessible (green rectangle). If you are replacing it, you can lift it out and lay the new one right in. There are no tabs holding it in place.
The purple rectangle indicates a repair that I previously made. Your ZEN will probably not have electrical tape on the board here.
The 2nd picture shows the LCD and button board removed from the case. The actual buttons are on a rubber sheet that can be removed as well.
These are just some extra interesting pics of my ZEN.
1st pic: the other side of the main board. The large thing in the middle is the SD card reader.
2nd pic: I had to take this picture through a jeweler's loupe. This ZEN suffered an unfortunate swim in a pool, and the power pins of the memory modules (blue rectangle) suffered for it. Amazingly, it didn't die from the water damage.
3rd pic: this is just something that impressed me. The item marked in red is an inductor, which is a bit of plastic or metal wrapped with wire. This inductor in particular is about a millimeter long. The wire wraps about 0.5mm, and there are between 10 and 20 wraps of wire in that space. That's just amazing.
the first pic indicating two circles are the power IC which burns out while charging it with wrong chargers.
7 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Many thanks. That helped me a lot, just ordered replacement battery :)
Excellent guide, thank you. I just used it to replace the battery in my Zen. May I offer a few pointers:
1) I find that doing the initial prying of the case can be done better with a small pocket knife blade rather than a screwdriver. It makes fewer marks on the case if you're careful to force the blade directly down into the crack (almost a millimeter), then rotate to pry up the case. Of course, care must be taken not to slip and cut yourself ...
2) If you're only changing the battery it is not necessary to go beyond step 7 ... no need to remove the battery tray. Just use a knife to gently pry the battery from its adhesive. Be careful though, the battery is flexible and you don't want to rupture the case or bend it too far.
3) Be sure when reassembling that you position the switch slider in the case, properly over the switch on the mainboard ... otherwise you'll have to open it again like I did. ;{)
Many thanks, this was extremely helpful.
very helpful post, I also used a small blade to open the case and had a completely smooth battery change. .. Many thanks, as the waste bin has missed out on being the new home for my Zen.
Finger nails are a good option to open the case - no damage (to the case - and if your nails are strong and flexible they will not be damaged either!) and non-conductive.
excellent !many thanks, but I think it ie near impossible to find out a new battery. Can you tel me hi tenzion so I can replace with an external one (not an elegant solution)
Successful battery replacement - button wire desoldering not necessary. I used a piece cut from a plastic card (credit card or similar) and a cocktail stick to pry the battery off its sticky strip. Thumbnail into the crack between the casings just where the SD card slot is (this is the most flexible area) and slide towards the corner farthest from that same slot with the thumbnail inclined towards the wider side (away from the screen) - this helps pop the catches. And then on around the case. Once you get to the corner coming up to the side with the usb port the whole thing should come apart “hinging” on the side with the port. Thumbnails don’t mark the case. Mine was also a victim of a dunking accident and I was really surprised that after a day or so drying out, it would work with a power supply from a usb. I tried using a power pack, but the one I have seems to shut down because the Creative doesn’t draw enough power to keep it awake.
On getting a battery if you are in a place where the Brazilian river doesn’t deliver: you could try buying a cheap MP3 player or other device and see if it has a battery with the right dimensions and voltage. The ones on the Ipod shuffle lookalikes are too thick - I tried it.
