Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
Make sure the camera is turned off here.
Remove batteries from the battery compartment located on the bottom of the camera
Remove SD card for the card reader compartment located on the flat side (left side) of the camera
Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
Use minimal force so that the plastic casing does not break
When separating the small silver sliding indicator for view/off/playback may fall out
The plastic viewing window located on the top of the camera may also become lose and fall out
