Ana içeriğe geç
Disassembling Epson PPC650 Replacing Flash
Neye ihtiyacın var
  1. Disassembling Epson PPC650 Replacing Flash, Case: adım 1, 3 resimden 1. Disassembling Epson PPC650 Replacing Flash, Case: adım 1, 3 resimden 2. Disassembling Epson PPC650 Replacing Flash, Case: adım 1, 3 resimden 3.
    • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
    • Remove the batteries from the battery compartment located on the underside of the camera.
    • Remove the SD card from the compartment located on the flat, left side of the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Epson PPC650 Replacing Flash: adım 2, 1 resimden 1.
    • Remove the two screws on the rounded side of the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Epson PPC650 Replacing Flash: adım 3, 2 resimden 1. Disassembling Epson PPC650 Replacing Flash: adım 3, 2 resimden 2.
    • Remove the three screws on the flat side of the camera.
    • All of the silver screws go into the side of the camera that is silver.
    • All of the black screws go into the side of the camera that is black.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Epson PPC650 Replacing Flash: adım 4, 1 resimden 1.
    • Remove the four screws from the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Epson PPC650 Replacing Flash: adım 5, 3 resimden 1. Disassembling Epson PPC650 Replacing Flash: adım 5, 3 resimden 2. Disassembling Epson PPC650 Replacing Flash: adım 5, 3 resimden 3.
    • Separate the front and the back pieces of the camera's plastic casing using a spudger.
    • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
    • Use minimal force so that the plastic casing does not break.
    • When separating the small silver siding, the indicator for the view/off/playback may fall out.
    • The plastic viewing window located on the top of the camera may also become lose and fall out.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: adım 6, 3 resimden 1. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: adım 6, 3 resimden 2. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: adım 6, 3 resimden 3.
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Epson PPC650 Replacing Flash: adım 7, 1 resimden 1.
    • Remove clear rubber band holding flash in line with wiring.
    FixBot'a Sor
    Yorum Ekle
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    FixBot'a Sor
    Yorum Ekle
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Xan Danes
134 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 üyesi
OSU-BUEHL-S13S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 629
