Parçalar
Hiçbir parçaya gerek yok.
  1. To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown).  The back panel is the same as the battery. With your index finger, push in the button on the bottom of the battery to release it. Pull the battery away from the phone.
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. After removing the battery, the front phone casing becomes accessible. Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles. Remove these two screws using the Torx T6 Screwdriver.
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Locate the top two U-shaped screws on the back of the phone, as shown by the red circles. Remove these two screws with a SP 2.6 screw driver. Note:  Remove gray plastic grommets with screws.
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  5. Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image. Note:  Be careful not to damage the circuit board and components as you as open the casing.
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
  6. After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown. After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
    • After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
  7. To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen. Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown. Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
    • To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen.
    • Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
Sonuç
Niccolas Tones
55 İtibar
9 adet Kılavuz yazıldı
Takım
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 üyesi
CLEM-BENSON-S12S1G1
3 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,052
